Approximate Purchase Date: This month
Budget Range: Absolutely no more than $550(still might be pushing it)
System Usage from Most to Least Important: CAD, emails
Are you buying a monitor: No
Parts to Upgrade: Everything except maybe the DVD drive
Do you need to buy OS: Supposedly. But I just want the price of hardware for now.
Preferred Website(s) for Parts: Preferably all from the same site, but it won't hurt to buy from different sites if it saves me some $$$
Parts Preferences: At least an i5 please
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1080p
Additional Comments: My client/father would like to have a small case because there is limited space where he is working.
And Most Importantly, Why Are You Upgrading: My client has been using a 5 year old XPS from dell for his CAD renderings. From a scale from 1-5(1 being unbearably slow, 5 being smooth has butter) his computer has been running this program at about a 2. So, its about time to upgrade.
Edit:
This is my build so far:
http://pcpartpicker.com/p/DZUa
CPU: Intel Core i5-3470 3.2GHz
Motherboard: MSI H61M-P31 (G3) Micro ATX LGA1155
RAM: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600
Storage: Crucial V4 128GB
GPU: MSI Radeon HD 6670 1GB
Case: Fractal Design Core 1000
PSU: Corsair Builder 430W 80 PLUS Bronze Certified
There is no big storage component because he is hooked up to a server. Any advice about my build would be greatly appreciated. Thanks
Overclocking: No
Edit:
