Years back I build a Shuttle computer with a P4 2.8 ghz and 2 gigs of ram, with a 128mb GPU lol. It was top of the line at the time!
Anyways, just wondering what peoples opinions were on them nowadays. I'm torn between using a Shuttle barebones and just building my own ITX system.
If I was going to use a Shuttle, this is what I would start with :
http://www.newegg.com/Product/Product.aspx?Item=N82E16856101129
I would add the HIS 7950 which exhausts heat, so it would actually help keep the system cooler, along with an i5 CPU.
The Shuttle PSU (at least according to Shuttle's forums) is made by Seasonic, so its a sturdy PSU.
I would also add the WiFi attachment since I am always on wireless.
If I were to build my own, I'm not really sure what I would use for a case to match that same foot print. And then I have the issue of also fitting a cooler inside. Any suggestions?
