Sign-in / Sign-up
Solved
Will my PSU power a 7750?
  • Radeon
  • GPUs
  • Power
  • Motherboards
  • Graphics
  • Product
Last response: in Graphics Cards
Anonymous
January 2, 2013 1:00:56 AM
Hello, I have a 400W Anec PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
it currently powers my
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I am wondering if the PSU will also be able to power this GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
My resolution is not very high ( 1440 x 900 ) and I don't overclock anything. Will I be able to run that GPU fine?
Thanks!
More about : psu power 7750
Best solution
a b V Motherboard
January 2, 2013 1:14:02 AM
Yes, it can. The 7750 is a very low power consuming card
Anonymous
January 2, 2013 1:17:46 AM
Best answer selected by josh980.
m
l
Anonymous
January 2, 2013 1:18:07 AM
Ok thank you
m
l
