you dont understand NOTHING on this string.
i said
Quote:
there isnt 32GB limit on Win 2000 nor Win98.
i had a 40GB in one primary 40GB partition in FAT32 with 98 on it first & XP next.
(i upgrade it later with NTFS)
in reply someone said
Quote:
So if there is a limitation (you say there isn't), then why does Microsoft say there is?
<A HREF="http://www.microsoft.com/windowsxp/home/using/productdoc/en/default.asp?url=/WINDOWSXP/home/using/productdoc/en/choosing_between_NTFS_FAT_and_FAT32.asp" target="_new">
http://www.microsoft.com/windowsxp/home/using/productdoc/en/default.asp?url=/WINDOWSXP/home/using/productdoc/en/choosing_between_NTFS_FAT_and_FAT32.asp</A>
in reply i said
Quote:
i know what Microsoft said.
but did you tried it by yourself ? (FAT32 with win98 of course!)
i did.
now i can draw it if you dont understand yet
lol
if you know you don't know, the way could be more easy.
