Help with build
It's been 5 or 6 years since I got myself a new pc. Now looking to buy or build a new pc that won't give me as many problems as my last pc did. My current pc which I have taken apart has a Q6000, 8800GTX, Asus P5E, 520w Corsair PS and 2GB of RAM with an Antec 300 case. I originally spent over $2,000 on that build, over the years it has slowed and the performance is anywhere but consistent. I'm over this and I need a reliable pc.
I have read lots of threads in this forum to try and get an understanding of how to build something that will work.
Willing to spend up to $1000 but happy to throw in maybe $200 more to make the computer faster and consistent etc
I need my new pc to be reliable and work efficient (no crashing or slowing when multi tasking or lots of programs running, need to be able to study and research for university without bad pc performance) I couldn't be more serious about having a fast running system that wont slow or crash.
Video and sound (I used to be in regular competitive gaming so I understand the need for stable video performance, high frame rate. I am over having FPS spikes and getting horrible frame rate lag. I need reliable sound to hear enemy noises, footsteps and user actions etc in game)
Hopefully with all that in mind some of you have a few ideas for a stable and reliable build that you also would be happy buying if you were in my position. If you have read this far, thank you.
Any questions just ask.
3 answers Last reply
More about help build
  1. http://www.microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
    190.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820148662
    60.00 if you want more ram then get the 2 by 8g kit for 90.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131848
    149.00
    if your not going to sli you can pick up a smaller mini atx motherboard.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
    90.00
    or there the cx for
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040
    70.00
    the tx is the model above the cx.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822149407
    109.00 (the one tb drives are 30-40 cheaper.).
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
    140.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
    80.00
    818.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814202025
    239.00
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125441
    280.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16833320074
    26.00 (wifi card)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052
    40.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181031
    100.00
    right now the i5 3570 3570k is the best cpu for the money. if you need more power look into an i7 cpu. with ram of the system to keep it stable pick up a good set of 1600 ram. the biggest thing you can do with new motherboard with digital vrms is buying a good power supply and make sure it 100w larger then the power supply vendor say you need. most of the gamer issue here on tom are from rigs that when stressed will shut down or screen will blank out or bsod. good clean power under stress needs a good brand power supply and have it sized rights. ssd stay with name brand units..most of them will have gotten out there firmware bugs out. also want to spend some money on good case fans and or a fan controller. most good case fans if you can keep them under 1000 rpm you never hear them.
  2. In my country those parts are more expensive at different stores.
    I am all for more power but really don't want to spend more than $1000, only extra if I really need to.
    I'm happy to go with the i5 over the i7 and I don't plan on having more than 1 graphics card.
    Not keen on the water cooling because I don't know anything about it.
    Is there an alternative to water cooling or is that the best way to go? I wan't to keep it as simple as possible.
    smorizio based on what you suggested I looked at some stores and found these local to me. (Want to pick them up to save shipping costs etc)
    Intel Core i5 3570K
    ASUS P8Z77-V-LK MB
    Corsair 16GB Kit (2x8GB) PC-12800 1600MHz DDR3
    Western Digital 1TB WD Blue SATA III 7200RPM 64MB
    Asus DRW-24B5ST 16x DVD+-R
    Asus Xonar DG PCI Gaming soundcard
    ASUS PCE-N15 300Mbps 802.11b/g/n Wireless PCI-E Adapter
    Corsair CX-750v3 750W ATX Power Supply
    I can get most of that cheaper at other local stores too.
    I already have an Antec 300 case. Can I use that to save money? If not I found this.
    BitFenix Shinobi Mid-Tower
    I don't know about the gpu though. That's where I need some help now.
  3. the antec 300 is fine to reuse..just make sure your video cards are less then 279mm 11 inches in length .11"/279mm
    you lose one of the hard drive slots.the sound card right now is not needed the onboard sound chipset will work fine unless your into audio editing. the r200 is a better case for 10.00 more.
    http://www.scorptec.com.au/computer/48364-cc200r if you want to buy a new case.
    for cpu cooling this will work fine.
    http://www.scorptec.com.au/computer/45673-rr-212e-20pk-r2
    the 7870 and 7970 here in the us has best value for the cost. the 660/660ti and 670 for nvidia are the best value.
Homebuilt Performance Build Systems Product
