Ok bare with me since this is my first build. My system mysteriously wouldn’t turn on about a month ago.
I tested votages with a multieter on the psu. Every connection checks out and I can run an led fan off it just fine and can hear/feel the fan. PSU seems fine.
I checked the connection between the case power button and mobo - in my amateur opinion, it looked fine.
I tried the mobo power button - nothing.
I tried shorting the power burron pins on the mobo - still nothing.
So I figured it was a dead mobo right? So I go through the RMA for it and 3 weeks later ASRock sends me another one.
However… same exact problem. Nothing turns on, no fans, etc. Absolutly nothing.
I double checked the PSU and connections to the mobo. Supplemental and 24 pin. Everything seems fine. I’m not sure where to go from here. Please help, I’m getting desperate. I haven’t logged into Steam for weeks… getting withdrawl.
