Solved
About to buy $700 worth of parts.. help
Ordering my second PC ever, here are the parts. Please critisize me and the parts as much as possible, and make fun of them (only if they're bad)... If you think you can change anything to make it better, please go ahead.My budget is $700 including shipping and tax. Keep in mind I live in Canada and shipping is really stupid here eh?
RAIDMAX HYBRID 2 RX-530SS 530W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply - 49.99
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX - $99.99
Athena Power CA-GSB01DA Black 0.8mm SECC Steel ATX Mid Tower Computer Case - OEM - $25.99
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $79.99
MSI 970A-G46 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS - $83.99
HIS IceQ H787Q2G2M Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card - $229.99
Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model BLE2KIT2G3D1869DE1TX0 - $29.99
Total = $600
Shipping = $32.27
Tax = $75.89
Total + tax + shipping = $708.16
If there is anything you would change, please let me know
30 answers Last reply Best Answer
More about about worth parts help
  1. Best answer
    That PSU is complete crap. Get one from Antec, XFX, Corsair, or Seasonic.
    Get regular RAM (1600mhz)
    Get a slightly cheaper motherboard.
    Use this money saved to get an fx-6300 instead of the phenom.
    Yea, I know the PSU's crap. probably going to switch it.
    I couldnt find any cheaper 1600mhz ram :p Cheapest was actually 1866mhz
    I was originally going for the 6300, but I heard that the phenom will be better because it has 4cores/threads, and the FX is 3 cores/6threads. Do you know how big of a dif. there is between the phenom and 6300?
    Also, could you recommend me a cheaper mobo with Sata III? Does Sata III make a big difference when using a 7200rpm HDD compared to a SATA II?
  3. http://www.anandtech.com/bench/Product/102?vs=699
    Beats it everywhere.
    Make sure to get a PSU from the companies I listed. Raidmax is bottom barrel. Worst of the orst.
  4. I would just stick with your motherboard.
    Thx. Found an antec 430W for the same price, also 80+ certified. I'll try and fit the fx 6300 also.
    What are good cheap motherboards? Im aiming for one with Sata III, but if theres one like $20 cheaper without Sata III, that would be good enough.
    Whoah frick, my internet just messed up, just triple posted.. Ok thx, I'll stick with my motherboard.
    Thanks so much otherwise I would've been screwed without you haha :)
  6. triple messaged
    You will want 500w for your GPU. A 430w won't cut it.
    Get this mobo: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157323&nm_mc=AFC-C8junctionCA&cm_mmc=AFC-C8JunctionCA-_-Motherboards+-+AMD-_-ASRock-_-13157323&AID=10592396&PID=3938566
  9. tiny voices said:
    Do you know any PSU's that are under $70 that have 500W's?
  10. http://www.newegg.ca/Product/Product.aspx?Item=N82E16817207013
    This is an amazing PSU. One of the most reliable.
  11. Tmanishere said:
    OP is located in Canada.
  12. This Corsair is $55 http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139027
    Should fit the bill nicely.
    Ah, my bad! :p
  14. Thanks tiny voices for all the help, I just want to confirm this build for all compatibility and everything.
    AMD FX 6300 (or fx 6100....?)
    XFX Core Edition PSU
    Seagate 1TB
    asrock mobo
    Athena Power CA-GSB01DA Black case
  15. Everything looks good. Get this case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146076
    Its a million times better than the one you listed.
    Discontinued in Canada :(
  17. The case you listed will work, but won't have the best airflow and has a top mounted PSU so no cable-management.
    Thanks for pointing out the top PSU mounting place... It's just something I can't have due to where my computer is going to be placed. Thanks
  19. Hey tiny voices, I noticed in your signature you have the Corsair CX600, are there any light screeching sounds/high pitched squeaks at all? A lot of people are mentioning it on the feedback on newegg.
    No, that issue was fixed a while ago. Mine is perfect.
    Where will your case be which won't allow a bottom PSU?
    I have a desk with a little stand under it for a computer, and theres a whole only at the bottom to plug in the power cable, there is a little piece blocking the top part of the computer.
    EDIT: Thanks for all the help.. Would've been in the dump if it weren't for you, tyvm.
    Is there anything else I could upgrade possibly in the future to make this better?
  22. Ahh I see. Well in that case get whatever case you like!
    The mobo you recommended me says its Micro ATX, does this mean I need a micro ATX case, or would it also fit in a regular atx mid tower case?
  24. It will fit in a regular ATX case no problem. You should measure the space you have for the case and compare the measurements to the case dimensions on newegg. Often times those desks are made for smaller prebuilt cases, as is the case with my girlfriend's.
    So the price was a bit overload for me, so I decided to swap out the 6300 for a phenom x4 965. When I went to the checkout, it said something about it is an OEM/Retail product or something.. What does this mean?
    Also, is the FX 4100 better than the phenom 965?
  26. I would say to drop to a gtx660 (only slightly worse than a 7870) and keep the fx- 6300.
    On the canadian newegg, the gtx 660's cost more :/
    What I'll do is wait until I can afford the 6300.
    Thanks for everything tiny
  28. Anytime man! Always glad to help!
  29. Best answer selected by markus843.
New Build Systems Product
