AMD/ATI Radeon HD 7850 2GB Dual Monitor Problem.
  • Radeon
  • Dual Monitors
  • Monitors
  • Cable
  • Graphics
January 3, 2013 12:17:55 AM
Hi!
I am trying to connect my Samsung S24B300 monitor to my PC (graphics card: AMD/ATI Radeon HD 7850 2GB) using an HDMI cable. Previously I had connected it with a VGA cable using a VGA to DVI adapter, and this worked just fine. However, what I am attempting to do is set up dual monitors. My plan is to connect my main monitor (S24B300) to my PC using an HDMI cable and my secondary monitor (Samsung Syncmaster S22B150) using my old method of a VGA to DVI adapter. But, as stated in the title, connecting the monitor to the PC with an HDMI cable does not seem to be working.
I have tried switching the display from analog to HDMI, but it just shows a blank screen and then goes back to analog, I have also tried restarting the PC to no avail. I have confirmed the HDMI cable works by connecting a laptop to the same monitor, and I have also tried reinstalling monitor drivers, as on Device Manager only one monitor is detected even when both are plugged in, but installing the two drivers for the monitors just overwrote the previous one and did not add a second device to the list.
I posted previously, and was told that it may be a problem with the video card driver but to try someone who knows more about ATI/AMD, so perhaps someone could give more information on this?
If anyone out there knows how I could go about solving this issue or has had the same problem, please post.
Thank you :)
More about : amd ati radeon 7850 2gb dual monitor problem
January 3, 2013 2:48:55 AM
Did you enable the second monitor on your system? Right click on desktop > screen resolution
Did you configure the settings in CCC?
m
l
January 3, 2013 12:17:36 PM
When I go to Screen Resolution there is not a second monitor to enable. As for CCC for some reason I don't have it...
m
l
a b C Monitor
January 3, 2013 12:40:25 PM
As I am a Nvidia User, I don't know if AMD is same or not.
But Have you installed AMD Drivers?
Go to Screen Resolution
Press "Detect"
You'll see a New Monitor
Click on it
Now set it accordingly
m
l
January 3, 2013 12:51:36 PM
When I try to detect a second monitor nothing comes up, as in, it isn't being detected. It doesn't work trying to detect from device manager or the AMD control centre either.
I have installed AMD drivers.
m
l
a b C Monitor
January 3, 2013 12:53:53 PM
Have you clicked on the 2 Monitor and changed the settings?
m
l
January 3, 2013 12:55:17 PM
There isn't a second monitor to click on. Screen resolution shows only one monitor and clicking detect does nothing.
m
l
