New build help
It's gonna be my first rig
Mobo. Asrock z77 extreme 4
CPU. Intel I53570 k
Ram. 8 gig kit suggestions ?
Gpu. Hd 7770 sapphire
Optical. Some DVD rw
Hdd. Sea gate barracuda 1 tb
Case. Haf 912
Psu. Corsair cmpsu 600w gamer edition
O/s. windows 64 bit 7 or 8? Suggestions?
Are they compatible?
Do you guys think its solid for a budget first pc?
9 answers Last reply
More about build help
  1. Its very lacking in the GPU department. This will only game at medium settings.
  2. If you are not spending more for the GPU, then get a AMD fx 6300 cpu instead
  3. It's because I'm pretty tight in the budget I want it to be more all around and can play the games like bf3 , bioshock etc that's the only gpu I can get for the budget
    How bout the compatibility ?? Is it fine?
  4. Get an i5 5470 and an h77 motherboard. Basically no performance hit at all.
    Use the saved money to get a better GPU like a 7850.
    This will only play BF3 at medium as it sits.
  5. Would the 7850 play games better
  6. Yes, by a decent amount.
  7. What is your budget? I will put together a much better gaming computer for you.
  8. My budget is around 700
  9. PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($183.79 @ Amazon)
    Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($87.55 @ Newegg)
    Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($73.98 @ Outlet PC)
    Video Card: Zotac GeForce GTX 660 2GB Video Card ($194.99 @ Newegg)
    Case: NZXT Source 210 (White) ATX Mid Tower Case ($29.99 @ Newegg)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($54.99 @ Newegg)
    Optical Drive: Samsung SH-224BB DVD/CD Writer ($17.99 @ Newegg)
    Total: $687.26
    (Generated by PCPartPicker 2013-02-19 22:18 EST-0500)
    This will blow your build out of the water.
New Build New Build Systems Product
