Solved
Best build for 1100 $ neeed help
Last response: in Systems
you will be looking at something like this
PCPartPicker part list: http://ca.pcpartpicker.com/p/EJ1u
Price breakdown by merchant: http://ca.pcpartpicker.com/p/EJ1u/by_merchant/
Benchmarks: http://ca.pcpartpicker.com/p/EJ1u/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($225.75 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.57 @ DirectCanada)
Motherboard: ASRock Z77 Extreme3 ATX LGA1155 Motherboard ($104.99 @ Canada Computers)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($50.79 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Memory Express)
Video Card: Gigabyte Radeon HD 7970 GHz Edition 3GB Video Card ($452.68 @ DirectCanada)
Case: Cougar Evolution-W (White) ATX Full Tower Case ($85.08 @ DirectCanada)
Power Supply: Corsair Professional 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($89.25 @ DirectCanada)
Total: $1107.10
(Generated by PCPartPicker 2013-02-20 06:20 EST-0500)
Here is what I'd consider, if you need the 7970 GPU:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($223.79 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Amazon)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($50.99 @ Newegg)
Storage: Samsung 840 Series 250GB 2.5" Solid State Disk ($178.43 @ Amazon)
Video Card: Sapphire Radeon HD 7970 3GB Video Card ($392.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Corsair Builder 600W 80 PLUS Bronze Certified ATX12V Power Supply ($49.99 @ Newegg)
Optical Drive: Samsung SH-224BB DVD/CD Writer ($17.99 @ Newegg)
Total: $1099.15
(Generated by PCPartPicker 2013-02-20 06:27 EST-0500)
or
With 7950 and more storage:
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($73.99 @ Amazon)
Video Card: HIS Radeon HD 7950 3GB Video Card ($299.99 @ Newegg)
Total: $1080.15
(Generated by PCPartPicker 2013-02-20 06:32 EST-0500)
@lunyone
Instead of suggesting my own build, I just want to say that I'd strongly recommend switching out the Samsung 840 250GB for a Plextor M5S 256GB.
http://pcpartpicker.com/part/plextor-internal-hard-driv...
It only increases the price by about $11.50, but you get a significantly faster drive (granted that's arguably not important for a gaming system) with significantly greater endurance for the NAND flash.
I'm not saying that the 840's lower endurance necessarily will cause issues, it probably won't, but by my calculations with it, it's pretty close to being dangerously low. The small cost can be offset by a cheaper DDR3-1600 2x4GB memory kit if necessary.
Also, do you have experience with the V3 models of the Corsair CX series? I ask because I can't seem to find any professional reviews of them. The V1 and V2 models were pretty meh, but the V3s are rated for more power delivery and better efficiency at each wattage point, so they seem better. I'd just like some confirmation on them being better other than rated efficiency and power delivery, if anyone has any to offer.
Related ressources
blazorthon said:
@lunyone
I don't have any experience with the Corsair V3 model. I also don't have a link to a review of them (I'm thinking that because of the iffiness of the V1 & V2's that there wasn't any V3's sent out for review, but just a guess). I would think the V3 should be better, but who knows for sure. The price is pretty good and generally my experience with Corsair PSU's have been good (it's been a bit since my last purchase of one). This version of PSU is Bronze Certified, so hopefully that means it is at least decent for what you pay for.
Best solution
http://au.pcpartpicker.com/p/F4zQ
That build is for little to no CPU overclocking and it comes in at under $1050.
http://au.pcpartpicker.com/p/F4F2
This build is a little out of budget at under $1150, but has more overclocking headroom on the CPU. However, after a little thinking, I came to the conclusion that unless you're dead-set on significant overclocking on the CPU, the first build's lower price makes it the better option since the second build really isn't going to top out the first by enough for the extra money to be worth spending for a gaming system.
