Sign-in / Sign-up
Need help!
  • Radeon
  • Graphics
Last response: in Graphics Cards
January 3, 2013 1:17:58 PM
ok, so i just built my first computer and i am having some problems, my monitor is not being filled ( black lines on border ) and i dont know how to fix it i have tried changing the resolution but no help there.. any ideas on how to fix? im running off hdmi on a amd radeon HD 6800! thanks in advance :D
More about : question
January 3, 2013 1:22:39 PM
Are fans spinning (CPU and/or GPU) ?
Any lights on ... anywhere?
January 3, 2013 3:24:18 PM
BigMack70 said:
Go into CCC --> My Digital Flat-Panels --> Properties and then disable underscan.
Should fix the problem.
thank you that worked perfectly!
January 3, 2013 3:44:33 PM
just went to play just cause 2 and the lines came back, only when i play games though.. any ideas?
January 3, 2013 4:10:20 PM
BigMack70 said:
You could try googling around for "just cause 2 underscan fix" or something like that, but I never got underscan to go away completely when I was hooked up over HDMI on my old 7970. I eventually used a DVI-->HDMI cable that I had lying around and that got rid of the problem, so you could always just use an adapter or different cable since underscan is only enabled on HDMI--HDMI as far as I know.
seems alot easier to go buy an adapter! thank you anyway
