Amplifier produces a "crackling" noise through speakers when volume or
l/r balance is adjusted, then settles back to normal sound/function
when adjustment is made and the controls are left alone. It does it at
all volumes and strangely how bad the crackling noise is, depends on
how "heavy" you grab/touch the volume knob?? (perhaps pure coincidence
but i thought i'd mention it).
Does anyone know if this is a serious problem or one which can be
fixed without much hassle/expense, or should i get rid and replace.
(its only started in the last week or so.)
Sounds as if cleaning the controls would probably fix it.
Here's some advice from an old post, possibly a bit more than you need:
One uses a cleaner / lubricant designed for the purpose, such as Caig
De-Oxit, usually in a small aerosol can with a plastic extender tube. With
the valve on the can set to LOW, one sprays a bit of cleaner into the
control, aimed at the carbon element, if it's a potentiometer, or at the
moving and stationary contacts, if it's a switch. Work the control back and
forth numerous times. Usually we repeat the process.
There's other fine points - such as blowing out the dust etc first, and
packing tissue around the control to catch runoff and prevent a mess. Often
it's necessary to hold the unit at some impossible angle so gravity can help
get the cleaner where it needs to be.
I will often blow out the controls again with a compressor and repeat the
treatment, it's my belief that by so doing I blow out some of the debris
loosened by the cleaning process.
Mark Z.
Please reply only to Group. I regret this is necessary. Viruses and spam
have rendered my regular e-mail address useless.
"Andy wilson" <ajw@bushinternet.com> wrote in message
news:408fafce.0404110238.7bda5330@posting.google.com...
"Mark D. Zacharias" <mzacharias@yis.us> wrote in message news:<c5bahb$2qqehg$1@ID-180484.news.uni-berlin.de>...
> Mark Z.
---snip---
Don't blow, vacuum. You want to remove unwanted stuff, not permanently embed it.
"unitron" <unitron@coastalnet.com> wrote in message
news:ae27d822.0404121850.57c7ba35@posting.google.com...
With
and
Often
help
the
> > Mark Z.
> ---snip---
embed it.
