Solved
Building a gaming rig. Need help!
Hi, i'm hoping to build a gaming rig so i can play most modern games at medium-ultra with playable FPS like 45-30, although anything higher will be nice. Not sure on what i should build, AMD or Intel. Any help?
I am Considering putting an AMD Phenom II x4 965 and a Radeon HD 7770 or an Intel Pentium G860/ Intel Core i3 3220 and a Radeon HD 7770.
Budget Range: Preferably under $500 CDN After Shipping
System Usage from Most to Least Important: gaming, surfing the internet, watching movies
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: Ncix.com (Canada), Tigerdirect.ca, Newegg.ca
Parts Preferences: Not sure whether an Intel or an AMD Would be best
Overclocking: Maybe
SLI or Crossfire: Maybe Crossfire
Your Monitor Resolution: 720p or 1080p
Additional Comments: Call of Duty, Battlefield, Skyrim, Borderlands 2, etc
7 answers Last reply Best Answer
More about building gaming help
  1. PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: Intel Core i3-2120 3.3GHz Dual-Core Processor ($117.27 @ Amazon)
    Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
    Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($62.99 @ Compuvest)
    Video Card: Gigabyte Radeon HD 7770 1GB Video Card ($114.98 @ SuperBiiz)
    Case: Zalman Z9 ATX Mid Tower Case ($40.98 @ Newegg)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($54.99 @ Newegg)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($18.98 @ Outlet PC)
    Total: $530.17
    (Generated by PCPartPicker 2013-02-20 19:43 EST-0500)
    $30 over budget, should serve your purpose well though.
  2. I don't think with a $500 budget you will be getting 45 fps on ultra.
  3. Hi, I liked the builds. I noticed i3's are common in a budget gaming rig, I really appreciate the replies. Although I want to buy an i3, I think an AMD Phenom II x4 965 BE and a Radeon HD 7870 1GB would be a better build, in a sense that i could grab a better GPU.
  4. Best answer
    You can grab the 7850 with the i3, the i3 is a better cpu, check the parts in ncix.com and the combo i3+motherboard, it fits 500$ with the 7850.
    I might seem very "wishy washy" now but I am going to take your advice and grab a radeon 7850 and the i3+mobo bundle you suggested with 8gb ddr3 kingston Black ram from nicx.com :D Thanks for the help
  6. Best answer selected by antixher025.
Gaming Build Systems Product
