Hi,
I'm planning to build a PC for under $1000 for my audio production work. At the moment I only use a dual core desktop which school were giving out for free (so it sucks). I've researched and because I want to keep the price as low as possible I have decided to go with AMD instead of Intel.
What I plan to do is whenever I need to upgrade my computer I will just build a completely new one and use the older one as a slave computer to connect to my host computer.
I have not decided on a graphics card yet but I'd like a quite cheap 1GB one because I don't plan to be playing games on it only using music software. If you have any suggestions that would be great!
Here's my build so far:
Case: CM Storm Trooper [SGC-5000-KWN1] (window) Black http://www.cmstorm.com/en/products/chassis/Trooperwindow/
MB: AMD AM3 ASRock [970 Extreme3]
http://www.asrock.com/mb/AMD/970%20Extreme3/
CPU: AMD AM3 FX-6100 Black Edition Six-Core 3.3GHz
http://www.amd.com/us/products/desktop/processors/amdfx/Pages/amdfx.aspx
PSU: 650W Cooler Power [P4-PTI-3]
http://www.itestate.com.au/pages/product/pdt_product_detail.faces?BeanName=productDetailAction&pcode=35559
HDD: Internal 3.5" 1TB SATA3 7200rpm HGST 7K1000.C
http://www.hgst.com/internal-drives/desktop/deskstar/deskstar-7k1000c
SSD: 2.5" 120GB Sata3 Kingston V300 [SV300S37A/120G] (R:450MB/s W:450MB/S)
http://www.kingston.com/us/memory/search/?partid=sv300s37a/120g
RAM: DDR3 Ram 8GB Kit (2x4GB) PC3-12800 1600MHz Kingston
http://www.itestate.com.au/pages/product/pdt_product_detail.faces?BeanName=productDetailAction&pcode=15572
I also have a cheap CD/DVD drive already.
This Build $661 (not including postage)
Basically I'm looking for any advice for anything I have to add or anything which you recommend I change. Also am I getting a good price for the build? What other components will I need to build this?
One more question do you know of any good 5.1 audio cards and will it work with my Motherboard?
This is my first time doing any of this so I'm sorry if I'm asking some pretty basic questions.
Thanks heaps,
Caleb
Thanks heaps,
Caleb
