Tom's Hardware > Forum > Audio > Audio Technology > comp monitor buzz in mic channels help!!!
Forum Audio : Audio Technology - comp monitor buzz in mic channels help!!!
Archived from groups: rec.audio.tech (More info?)
I have a computer monitor next to the mixer (biamp 16x4x2) and I pick up
this buzzzzzzz in mic channels from the comp monitor... What can i do to
eliminate it ??
Is it a poor shielded monitor or will all monitors rediate rf into audio
channels??
don ward
don ward <dward7@earthlink.net>
Sponsored Links
dward7@earthlink.net (don ward) writes:
> eliminate it ??
> channels??
CRT monitors work by accelerating eletrons to nutty velocities and
smashing them into colored dots on a phosphor screen. There's likely
not a worse noise source in your home.
Move the mixer far far away--the radiation falls off with the square
of distance. Better still, buy a flat panel LCD monitor which are far
far quieter with respect to EMI/RFI.
Best Regards,
/"\ ASCII Ribbon Campaign | Todd H
\ / | http://www.toddh.net/
X Promoting good netiquette | http://triplethreatband.com/
/ \ http://www.toddh.net/netiquette/ | "4 lines suffice."
Reply to Anonymous
On Tue, 13 Apr 2004 01:26:58 GMT, dward7@earthlink.net (don ward)
>eliminate it ??
>channels??
Some are worse than others. But the obvious answer is to put some
space between monitor and mixer, keep audio wires away from the
monitor video cable.
On my Atari Falcon system, some years ago, the audio recording routine
included "switch off monitor". It made surprisingly little obstacle
to my recording :-)
If the problem won't go away, consider a non-crt monitor.
Reply to Anonymous
There are 1330 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
