4 Display Multi Monitor Setup
January 5, 2013 11:57:31 AM
Hi
I am looking for a graphics card with 4 dvi outputs. They should be mounted on the graphics card and not using DMS cables.
I have looked at the Galaxy GTX 560 MDT x4 but I have heard that they will not do 4 individual configurable displays but will do 2 display spand across 2 monitors.
I can not use two graphics cards for this job as my other two PCI express slots are being used for other GPU's.
The GPU should be able to have 4 displays running individualy controlled and not a spanned desktop.
Thanks
