NEW BUILD:
Case: BLACKHAWK ROSEWELL FULL TOWER
Power Supply: Corsair 1200watt 80+ Gold
CPU: AMD FX-8350 8-Core
HDD: 3TB Seagate 7200.RPM
SSD: 120GB OCZ (for operating system boot-up)
MOBO: GIGABYTE GA-990FXA-UD7
RAM: G.SKILL Ripjaws Z Series 32GB (4 x 8GB) DDR3 (1866)
GPU: GTX 690 GeForce EVGA
MONITOR: 27Q CROSSOVER
So here are the questions i want ask:
If money where no option What would you change? and what would you Upgrade?
If you where on a buget or $2'800 - $3'200 ... give or take... what would you Change? and what would you Upgrade?
AND THE BIG QUESTION! -- Will Any of these products BOTTLENECK the GPU! listed above.
