Archived from groups: alt.cellular.nokia (More info?)
I have a Nokia 3360 phone. The basic nickel battery has done fine, but
is over 3 years old, and I suspect it's getting a bit weaker on talk
time. I plan to order the lithium BLC-2 battery. From what I
understand, these have changed mAh rating over time; i.e., initially
some were 650 mAh, then 850 mAh, 950 mAh, 1050, etc. An online seller
says his BLC-2 battery is an OEM Nokia 950 that he gets in bulk, not
packaged, but does say Nokia on the battery. When it arrives, is there
anyway to verify that is rated at 950 mAh? Should the 950 be printed
on the battery markings? Thanks.
