Heat/noise issue. Should I upgrade or build a new system?
About a year ago, I customised my first gaming desktop PC, and here it is:
CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor (not OCed)
CPU Cooler: Stock cooler that comes together with the CPU
Motherboard: Asus P8Z68-V Pro/Gen3 Motherboard
Memory: Cosair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Hitachi 500GB 3.5" Internal Hard Drive
Storage: Intel 520 Series 180GB 2.5" Solid State Disk
Video Card: EVGA GeForce GTX 570 4GB Video Card
Case: CM Elite 311 Plus
Power Supply: Cooler Master eXtreme Power Plus 550W
Optical Drive: Samsung 24X DVD writer SH-S243D
Use: gaming ( BF3, BO2, Dota2, SC2, Skyrim ), Surfing & watching movie.
I have no problem with this system until recently I noticed that the system generating high heat & noise.
I tried cleaning (airblow) inside the system, but no use.
How can I solve this noise/heat issue?
Should I upgrade ( <$700 ) or just build a new system ( <$1500 )?
Please forgive me if there's any mistake. Thanks for the help.
1 answer Last reply
More about heat noise issue upgrade build system
  1. Heat, could u specify about the what heat? GPU or CPU? or else?
    Noise, try setting fan profile so it will became quieter...
    (but it will need the heat problems solved first)
Homebuilt Systems
