New Monitor, HELP!
Hey guys! just got a new 23 inch 1080p monitor and i need help getting the screen fixed. Everything works fine but look and the picture and you'll see that youtube is like all the way to the left for some reason. leaving the entire left side just a bid empty white area. is there a way to stretch it out and make it look like normal but keep the 1080p quality?
1 answer Last reply
More about monitor help
  1. make sure your running the newest video driver. in most control pannels in windows there are default video settings then there a box or check mark to show all video settings. make sure that clicked then scroll down and look for 1080 settings. on some windows it a box under monitor that says hid setting my monitor cant show uncheck that.
Graphics Cards YouTube Monitors Graphics
