Solved
Help with building a gaming system?
Last response: in Systems
Hello,
I am thinking of building a gaming pc, my first one, and would like help. The hardware I'm looking at so far is this
http://www.amazon.com/LGA1155-CrossFireX-Motherboard-Z7...
http://www.amazon.com/Samsung-MZ-7TD250BW-Series-Solid-...
http://www.amazon.com/Corsair-Vengeance-Desktop-Memory-... ram
http://www.amazon.com/Gigabyte-Mini-Displayport-PCI-Exp... HD 7870 LE
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Pro... 3570k
A couple questions
Are these all compatible?
What else do I need?
Would you reccomend any alternatives for what I do need?
Thanks in advance, it's my first build and I'm hoping to get some advice from experienced people.
More about : building gaming system
Homebuilt system Authority
Gaming Authority
CPU : http://us.ncix.com/products/?sku=70541&promoid=1302
RAM : http://us.ncix.com/products/?sku=74758&promoid=1321
MOBO : http://us.ncix.com/products/?sku=71114&promoid=1302
It's a good motherboard for the price, you can get cheaper parts in ncix us, and with free shipping(over orders that are more than 100$), also you don't need the ram at 1866, since the speed difference will be negligible in the performance, and with really tall heat spreaders, which will not give much clearance to an aftermarket cooler
That's not the 7870 tahiti le, get the sapphire 7870 XT, which is a tahiti le : http://www.amazon.com/Sapphire-Radeon-PCI-Express-Graph...
I would get a ssd with mlc nand over tlc(the samsung 840 non pro has tlc nand), it's faster and it will have more endurance :
http://www.amazon.com/dp/B004W2JL2A/?tag=pcpapi-20
Also you'll need an aftermarket cooler, if you want to overclock the cpu, if you don't have one :
http://www.newegg.com/Product/Product.aspx?Item=N82E168... or
http://us.ncix.com/products/?sku=64385&promoid=1302
Best solution
PCPartPicker part list: http://pcpartpicker.com/p/Fwwm
Price breakdown by merchant: http://pcpartpicker.com/p/Fwwm/by_merchant/
Benchmarks: http://pcpartpicker.com/p/Fwwm/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($31.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($124.99 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($49.48 @ Outlet PC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($75.98 @ Outlet PC)
Video Card: Sapphire Radeon HD 7870 XT 2GB Video Card ($244.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($54.99 @ Newegg)
Optical Drive: Samsung SH-224BB DVD/CD Writer ($17.98 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $930.36
(Generated by PCPartPicker 2013-02-23 19:30 EST-0500)
  • benraskull selected this answer as the solution
Related ressources
