Ok so i just bought a second hand Samsung Syncmaster 2233 3D monitor, and i'm now trying to set it to display at 120hz, but whenever i do this the monitor blacks out and comes up with "check signal cable" ive tried using multiple Dual DVI cables to no success.
I am currently using an Asus Nvidia Gtx 560 graphics card on this system, with current up to date drivers *310.90* can anyone help with this problem?
If it helps i also cannot run the monitor on its own, it requires a second monitor to be plugged in otherwise i get the same warning on screen.
