Closed Solved
Help Guys, Quick Question
Will my emaxx emx-ih61le-icafe MOBO be compatible with a Radeon HD 7870 GPU?? my main concern being the 2 pci-e slots needed to power it
3 answers Last reply Best Answer
More about help guys quick question
  1. Best answer
    Where did you read that you needed two PCIe slots? It need two PCIe connectors from the power supply unit, not the motherboard.
    Concerning the motherboard, it will work just fine. Make sure you power supply unit is up to the task, though!
  2. It will work.make sure that you have good cpu with hd 7850.
  3. Best answer selected by RonSolid.
Graphics Cards Compatibility Graphics
