Problem with powercolor hd 7870
hey i have recently purchased a powercolor hd7870 2gb myst edition (http://ncix.com/products/?sku=78372) on ncix, when I tested the gpu, first, the gpu fan will start turning, and then stop, after i give it a little push, it will start turning again without problems, this happens everytime when i start my computer. Also, the gpu has coil whine issue, I heard from other sources that it is not a big issue affecting the life expectancy of the card, but I would like to hear you guys' opinion
thanks
3 answers Last reply
More about problem powercolor 7870
  1. Coil whine is normal. They can be heard on motherboards and psu as well.
    About the card, if you don't give it a push, will it spin later? Did you get any display and if you did, are temps normal during gaming?
    I did not let it sit without spinning, I will try this tonight and tell you about it
  3. in ccc > performance > amd overdrive
    what does it show the fan speed set at?
Radeon GPUs PowerColor HD Graphics
