Can this build run skyrim on ultra settings?
Here is the build:
Monitor: 22" HD Super Clear Glare-Type Screen Processor: Chipset: 2nd Generation Intel Core i5-2450M 3.4GHZ (OC) Standard Hard Drive: Standard Optical Drive: 750GB 5400RPM Hard Drive (Upgradeable) 1 Detachable 2.5" 9.5mm (H) SATA Hard Disk Drive No Optical Drive Bay (External Optical Drives Available) Graphics Graphics Controller: nVIDIA® DUAL GTX 580 SIDE BY SIDE 8096 MB DDR3 1333MHz (Upgradeable - 16GB 1333MHz Max) Two 204Pin SODIMM Sockets 64-bit Wide DDRIII Data Channel Audio Features Audio Features: Built-in Azalia Compliant Audio Chip, with 3D Effect & Full Duplex 3D Stereo Enhanced Sound System Sound Blaster Compatible / SRS Premium Sound 4 x Built-in Altec Lansing Speakers 1 x Built-in Microphone S/PDIF Digital Output Network Network / Communication: Built-in Gigabit Ethernet LAN Integrated 802.11 b/g/n wireless LAN + Built-in Bluetooth 3.0 Slots / Interface Card Reader: Input / Output Ports: 5-in-1 Card Reader SD / MMC / MS / MS-Pro / xD 2 x USB 2.0 Ports 1 x USB 3.0 Port 1 x HDMI 1 x RJ45 LAN 1 x VGA Port/Mini D-Sub 15-Pin for External Monitor 1 x Microphone 1 x Headphone Out Jack (S/PDIF) Power System Battery: Input / Output: 8 Cells - Smart Lithium-Ion Battery Pack (5600 mAh) 19 V DC, 4.7 A, 40W | 100~240 V AC, 50/60 Hz Universal Cooling. Thanks!
2 answers Last reply
More about build skyrim ultra settings
  1. if anything, weakest link is the cpu. its a dual core with 2 hyper threads running your gpus
  2. Nope... Medium-high is more playable
Prebuilt Systems
