Archived from groups: alt.cellular.nokia (More info?)
i have recently just got a nokia 6630 and when i go to make a call it
says network busy or connection error! but i can still send texts and
if i try to connect to the net it say pocket data not available! so i
rang vodafone and they said the network is fine. but every now and then
it will be fine but only for a couple of hours then it does it again! i
have only started to get this problem ever since i plugged it upto my
pc and uploaded a couple of themes.
has anybody had this problem and solved it or does anybody know how to
do so?
I have tried the *#7370# reset but that aint worked!
i dont know if i'd need to reflash it and if so what programm i need to
do so or the place to get the correct firmware from!
