Hello,
I'm putting a system together with:
Corsair HX750 Gold PSU
Fractal Define R4
Asus P9X79 Pro
My query is that the case has a series of cables that connect to the front panel (power on, reset, LEDs + USBs)
These connect to the mobo via various connections - which is OK, I have them connected.
There are also 3 cables / terminals bound together that I assume need to be connected.
One is a 4 pin power connector (HD / DVD type) - which I've connected to the PSU.
The other two are 2 pin (small) set in a rectangular surround - and I'm not sure what these connect too at all, whether they need separate power connections to the PSU, or need to connect to the Mobo. The PSU has no leads with it that will fit, and there are no terminals on the mobo that appear to fit.
I'm also wondering whether the power lead I've connected is really necessary, and if not, and I likely to cause any damage ? If it is to power a drive,
I'm trying to grab a photo to post to explain the above.
Thanks.
Fractal Define R4
Asus P9X79 Pro
Thanks.
