Will this system get good frame-rates?
Hello everyone, I'll get straight to the point. I'm about to build a new PC for a friend (he's obviously paying me for the parts, and man-hours) and I was wondering if this would suit his needs. I've build plenty of PC's before, but I've been out of the game for about 4 years, so I'm generally unfamiliar with this generations tech. Here are the specs:
Case: NZXT Phantom Mid-tower
Fans: 5 in all - 2 intakes in front, 1 intake on side, 2 exhaust on the top
CPU: AMD FX-8350 @4.0GHz (WILL OC to ~4.8GHz)
Cooling system: ZALMAN LQ-315 liquid cooling system
RAM: 16GB (8GB x 2) G.SKILL Ripjaws X Series DDR3 @ 1866GHz
PSU: Rosewell Lightning 1000Watt 80Plus Gold
HDD: 500GB Western Digital SATA II @ 2Gb/s
GPU: PNY nVidia GeForce GTX 660ti 2GB
LED: ''12 Blue Cold Cathod
What do you guys think? :)
Also, my experience with GIGABYTE boards are rough when it comes to Overclocking. Usually I run into trouble when OCing the RAM. On my old PC it would set the clock to 1333GHz when the sticks were actually 1866GHz. I would try to set it up to 1866GHz but the BIOS would give me a fail message and boot up back to 1333GHz... thoughts?
5 answers Last reply
More about will system good frame rates
  1. Looks like a good solid mid to upper-midrange gaming PC. I am a bit confused as to why all the fans are intakes however..
  2. Good question! Well I'm concerned about pressure! It has 5 fans... I'm not sure what the intake/exhaust ratio should be.
  3. Generally its intake from the front/side and output through the top/back.
  4. Oh sorry typo!! Meant to say that the two on the top were exhaust. Making 3-intake and 2 exhaust.
  5. That should be fine for the fans. Do you plan to do SLI/TriSLI with the GPUs? Otherwise the 1000 watt PSU is overkill. The butterzone would be 650-750w for that build.
Prebuilt Systems
