Low power home theater
  • Tuner Cards
  • Home Theatre
  • Power
  • Graphics
February 14, 2002 9:24:49 PM
I'm trying to put together a high power (CPU) and a low power (Watts) home theater system. The case I bought only has a 200 Watt power supply, so I do have a limit. The mother board I want to use is the Chaintech 7SID, which is the only MATX DDR MB I could find. For a CPU I'd like to use an under clocked Athlon XP 1500+. (100MHz FSB) I planned on running XP, so I was going to put in 256MB of RAM. For a video card, I was thinking of one of the 7500 AIW. Sound, I'd like one of the new Sound Blasters, with Digital out. Will this float, or am I going to get smoke???
Any other suggestions?
Anyway to lower noise?
More about : low power home theater
Anonymous
February 15, 2002 9:46:54 AM
I will get a Duron and not Athlon as they are running much cooler, and use a passive Fan like the Zalman Gold, maybe even without the fan on it, depend on the final temp.
I will still use a bigger PSU, but probably a Enermax wisper using only one of the fans.
For a Display card I will use a Matrox, as they require much less power, run much cooler with only passive HS require and no fan. They also have the best TV out and DVD Max option.
Intel / AMD - <A HREF="http://www.llnl.gov/asci/news/white_news.html" target="_new">IBM are still the best</A>
February 15, 2002 10:30:12 PM
<blockquote><font size=1>En réponse à:</font><hr><p>Matrox... They also have the best TV out and DVD Max option<p><hr></blockquote><p>the best ones is Matrox ?
if you know you don't know, the way could be more easy.
Anonymous
February 16, 2002 12:27:31 PM
For TV out YES. They are also very good in power consumption.
They are bad in every thing concernes 3D.
February 16, 2002 1:24:46 PM
maybe you forget ATI, don't you ?
February 16, 2002 11:11:54 PM
Oops, forgot to say that the case is a Yeong Yang YY-A101 case, the only case I've found that will fit in a standard audio rack. It uses a SFX size power supply, and I haven't found a bigger P/S in this form factor. Any hints there?
Also, I'd like to use a 120G 7200 RPM drive in it, but if I have to, I'll move it out into a Firewire external case, and power that from a wall wort.
Thanks for the hint on the Zalman Gold. VERY cool Cooler! ;-)
February 17, 2002 3:38:33 AM
Oops, 200W PSU for this rig is maybe a little constrained :)
February 17, 2002 1:20:41 PM
i think you're strongly sure of.
you're certainly <i>right</i> :)
