Solved
Can someone tell me if these parts are compatible?
Hi, I am doing my first build for my friend's parents and I want to make sure everything will be compatible before ordering the parts. Thanks for your replies- they are very helpful!
CPU
Intel Celeron G1610 Ivy Bridge Dual Core 2.6GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116889
Memory
G.Skill Value Series 4GB 240 Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231421
Case
CFI Prime Black Computer case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811855005
MB
MSI H61M-E33/W8 LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130656
HDD
Seagate Barracuda 500GB 7200RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
DVD/CD
LG 24x DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
PSU
CORSAIR Builder Series 430W 80 Bronze Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Graphics Card
GIGABYTE GeForce GT630 1GB 128-bit DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125426
-Will this graphics card be able to output another VGA via the DVI with an adapter?
8 answers Last reply Best Answer
More about parts compatible
  1. Best answer
    Yes to both questions, but I suggest getting an H77 or B75 motherboard just to be safe if you're getting an Ivy Bridge CPU. Some H61 and other first-gen LGA 1155 boards do not ship with a Ivy Bridge-supporting BIOS and need it updated, but you need a Sandy-bridge CPU tp perform that update.
  2. What about this motherboard? Its H61 but it says "Microsoft Windows 8 Certified" and "Intel 22nm Multi-Core CPU support". Also it doesnt mention front panel connectors, is that just assumed it comes with the MB? Do not all MB's come with front panel USB connectors?
    Here is the MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135343
    EDIT: I just went on their website, and they had a list of validated CPU's, the Celeron G1610 being on there. Thanks for your help, I would have bought the wrong motherboard :O
  3. I think that pretty much all modern motherboards come with USB 2.0/1.x headers for front and/or top panel connectors, but some don't have USB 3.0 headers.
    Also, I'm not quite sure of what most of your last post is saying. If you have any current problems and/or questions, would you mind clarifying it a little?
    That was my question, on whether or not all motherboards came with the USB 2.0 front panel connection cords
  5. OK. I just looked at the pictures in that Newegg link and I can say that I don't see anything that looks like USB 2.0 headers. I think that that might be one of the only boards that lack them :(
    Technically, you could get them through an expansion card, but at that pint you might as well just get a different board instead of adding the complication of an add-on card.
    That's fine, I misunderstood him and he does NOT need to dual screen. So I am going with the original APU build using a A6-5400K paired with some 1866 memory. Can you tell me if this board has them?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661
  7. That it does.
  8. Best answer selected by yoyomah20.
Homebuilt Compatibility Systems Product
