Hello everyone!
An accident has happened and my PC might be ruined
I was asleep when my sister was using the computer and she had this rubber heater which has to be filled with water. And it somehow blew up.
The PC was on its side (cpu fan's mount brackets have been broken) and the water got in while being on.
She unplugged everything asap.
When I opened the case I noticed the MB was wet in some places.
The water got in though the two openings that are over the CPU and GPU. Removed the CPU fan and there was a single water droplet on the thing where you put the CPU in. And the MB battery was quite wet.
Dried the whole thing with a fan, made an attempt to start the PC, nothing happened. I remember there being this subtle electricity sound when the PC is off but plugged in, now there's no sound.
Tried to turn on the PC a couple of times with no luck.
I guess the MB is damaged, but what about the other components?
What I really care about the most is the GPU(which I bought a year ago, the rest is like 4 years old) and the hard dive (it would be such a shame to lose all the data)
How likely is that these components are damaged? Inspected the GPU, saw no trace of water but there was water right next to it on the MB. The water didn't get to the hard drive, could it somehow be damaged though?
I'd appreciate your help.
