An Improved Method of Noise Cancellation
Last response: in Home Audio
Archived from groups: rec.audio.tech (More info?)
FYI...
O-1 An Improved Method of Noise Cancellation—David Herman1, Dudley
Haestler1, Simon Busbridge2
1 AudioGravity Ltd., Hove, UK;
2 University of Brighton, Brighton, East Sussex, UK
The effectiveness of conventional noise cancellation techniques is
limited by tolerances between the signal and noise channels. A system
is described in which the ambient noise error signal is fed back for
further cancellation (Advanced Ambient Noise Rejection Technology,
ANRT). Small physically displaced microphones differentiate near-
field signals from high-level ambient noise. Band limiting filters
further reduce high-frequency phase distortion. The effectiveness is
increased such that an unintelligible signal produced by normal speech
can result in an SNR improvement of 40 dB in an ambient noise field of
98 dBA. The technology can be integrated into a single, small,
low-power CMOS analog integrated circuit; it is also ideally suited
for MEMS (Si-Mic).
....Moose
Moose <123@456.com> writes:
> it is also ideally suited for MEMS (Si-Mic).
"Si-"licon "Mic"rophone? Never heard of that - any more
references to such a device?
% Randy Yates % "I met someone who looks alot like you,
%% Fuquay-Varina, NC % she does the things you do,
%%% 919-577-9882 % but she is an IBM."
%%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO
http://home.earthlink.net/~yatescr
This is where I found the abstract: http://www.aes.org/,
http://www.aes.org/events/116/papers/O.cfm and these are all the paper
sessions with abstracts: http://www.aes.org/events/116/papers/.
Here is some stuff out of Stanford and the like which is what you are
looking for, I think: http://www.memsnet.org/mems/.
I have but scratched the surface myself and will continue to read and
look into this albeit experimental but fascinating.
Good luck...
....Moose
Ask the community
