Sign-in / Sign-up
Solved
Is 40mhz a big difference?
  • Graphics Cards
  • Core
  • Cooling
  • Sapphire
  • Graphics
  • Product
Last response: in Graphics Cards
January 7, 2013 9:52:52 PM
Hello, I'm looking to purchase a 7850 and I found two:
http://www.newegg.com/Product/Product.aspx?Item=N82E168... (Sapphire)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... (XFX)
The Sapphire's core clock is 900mhz, instead of the XFX which is 860. Is this a big difference? The Sapphire card is only 5 bucks more, so for now I have my mind set to it. I've also almost never heard negativity about Sapphire, and I heard their methods of cooling are great, too.
More about : 40mhz big difference
a c 89 U Graphics card
January 7, 2013 9:54:30 PM
for 5$ whynot, id say its worth it
m
l
Best solution
January 7, 2013 10:21:48 PM
It doesn't much but for 5 dollars, it's a good deal. Plus, Sapphire is a better card overall, so you are better off with a Sapphire card. Hope that helped! :)
January 8, 2013 3:36:00 AM
Best answer selected by MeicoPotato.
m
l
a b U Graphics card
January 8, 2013 4:25:23 AM
Just a extra note but its always good to think of things in percentages. The 40mhz means the sapphire is 4.65% faster than the xfx. The cost is $5 which is a 2.85% difference. So for a 2.85% in price you theoretically get 4.65% more performance.
m
l
January 8, 2013 11:38:45 PM
No! That is a misleading information. Clock speed is only one aspect of a video card so its not going to give you 4.65% more performance it will only give you that much more clock speed. There are so many things to consider when buying a new graphics card.
m
l
a b U Graphics card
January 8, 2013 11:50:49 PM
I did mention theoretically and it is considering cards that are almost the same in other regards
Its like saying a CPU clocked at 1.1ghz is 10% faster than if the same cpu is clocked at 1ghz. There are other restraints to performance like memory bandwidth, pcie neadwidth etc.
http://www.techpowerup.com/reviews/Gigabyte/HD_7770_OC/...
Not the best example to support my thoughts but here we have a card that is clocked 10% faster and it is giving about 8.7% more performance in most resolutions. It is not a perfect co-relation between clock speeds and performance but there is a high co-relation in most cases
m
l
January 9, 2013 1:46:19 AM
Misunderstanding...
m
l
