I have seen this problem before. It usually has to do with a fragmented HD or too little CPU available. I use a second HD specifically for capture that I keep defragged. If the #2 HD is on a different controller this will also help.
Normaly this kind of problems are deu to broken signal.
The can be fixed using a Device calld TBC or by recording your material to DV first and capturing from DV.
the most simple way will probably capture in 1 hour or less parts.
Intel / AMD - <A HREF="http://www.llnl.gov/asci/news/white_news.html" target="_new">IBM are still the best</A>
Exactly
and you get audio and Video Sync problems.
Record your material to VHS and capture from it. You still might need a TBC or dubbing to DV to get reed of the sync problems.
I highly recommend that you use Windows 2000 or XP, then get 2 HD's (I recommend the Maxtor 40GB 7200RPM ATA133 drivers) then connect them to another 133 IDE controler. By doing this you can use Windows 2000 or XP to turn the 2 HDs into one using Dynamic Disk Management, this also turns the drivers into a RAID array, allowing less skipped frames and will help utilize less CPU resources.
Here are My computer Specs:
Tyan Trinity 400 Pentium 3 Motherboard
1 Ghz Pentium 133 Processor
512 MB of SD133 RAM
AIW Radeon AGP card
Soundblaster live 5.1 value
(1) Maxtor 30GB 7200 RPM HD
(2) Maxtor 40GB 7200 RPM HD
Promise ATA 133 IDE controler
Windows XP Professional
By the way, I am capturing with less than 1% frame loss at maximum settings, my CPU usage never goes beyound 65% used up. I also have any Antivisus Programs disabled as I am doing this process.
