Solved
Woud these parts be compatible with the sapphire hd 6770?
Last response: in Systems
m building a low budget gaming desktop... but I'm not really building it. My uncle is... i just got to decide what parts I'm getting.I already have a gpu which is a sapphire hd 6770, and i want to try to crossfire it (double it). but if you can find a gpu from $50-160 that is better i'll take it. my computer has to be less than $700 or 600, if you want to update my list.
mobo:
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
RAM: CORSAIR Vengeance LP 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M1A1600C10B : http://www.newegg.com/Product/Product.as
VC: AMD Radeon sapphire hd 6770
http://www.sapphiretech.com/presentation
Intel Core i5-2500K Quad-Core
coolin system'
PSU
CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
Harddrive
I WILL BUY A HARD DRIVE (SEAGATE 2 TB ) AT BEST BUYS
Crossfire Bridge
27151256
DVD Burner
please help i have no idea if these parts will be compatible with each other?
Best solution
Homebuilt system Authority
crossfire 6770s isn't worth it. It will still be not as good as a mid range current GPU.
Get an hd 7850 or a gtx660
Get a more recent CPU and motherboard. Yours are almost 2 years old.
Get the i5 3570k and a z77 motherboard
For gaming, I would get an i5 3470 and an h77 motherboard. It will be cheaper and you won't need the cooling stuff because you cannot overclock.
This will give you more money to get a better GPU. This is the most important part of a gaming rig by far.
You picked a mini-ITX board. You do not want that. There are regular h77 motherboards. They are cheaper than z77 motherboard. Z77 boards are only for overclocking. If you aren't overclocking, which you won't be with an i5 3470, you only need an h77 board.
Related ressources
Don't waste money on a motherboard. The one you listed isn't even for intel CPU's its for the AMD FX series. Just because some people got a DOA doesn't mean you will. Get a $70-$80 motherboard and get a better GPU
The GPU is what you want to focus on most here. Gaming experience is all based on the GPU.
