Help me build
Hey guise. I want to upgrade a few components, but I'm on a tight budget right now.
CPU: 3570k or 2500k, leaning towards 3570, it's also cheaper. Any better choices for <$220?
Mobo: just a cheap one that supports the cpu. I'll upgrade later. Anything <$70?
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202011
or http://www.newegg.com/Product/Product.aspx?Item=N82E16814150598
not trying to run anything on ultra settings, just need something better than my hd4570...
if you've got a better card around the $120 mark let me know
I've got a 450w PSU
Help appreciated.
3 answers Last reply
More about help build
  1. GPU go for this
    http://www.newegg.com/Product/Prod [...] 6814202011
    do you plan on overclocking?
    you can go i5-3470 and go for H77/B75 MB...
    http://pcpartpicker.com/part/msi-motherboard-b75ma
    your PSU's brand?
  2. TimeLass said:
    your PSU's brand?
    Corsair. And no, I don't plan on overclocking, I think stock will be enough to run most games. Maybe in the future.
    hmm if you plan on overclocking in the future you should go for 3570K and a Z77 MB...however a Z77 MB is not that cheap...
Build CPUs Components Systems Product
