Hello,
Built a new pc this weekend and am having some issues. I have a MSI-Z77A-G41 1155 ATX running a i5-3570k processor. I have had 2 issues.
First, when I built the PC, the first time I powered it up it was fine. Then I moved the pc to its new location the system would not power on. I would get a flashing light on the Power on button. I opened up the case and I would unplug and plug in the system and the same flashing light would occur. With the case open I saw all the fans would spin for a half a second.
I re-seated the CPU, Hyper Plus fan, ram and graphics card. It still didn't work. I moved it to my build location from where the pc is finally going to be placed and all of a sudden it worked. When I moved it back it didn't work again for an hour. I left it, came back, unplug and plugged it in and it worked. Have not had this issue for two days and computer has been left on except for Windows update resets. No movement of the system, it is in its final location.
But new problem yesterday, the machine has 4 usb 3.0 ports (2 front and 2 back) and 4 usb 2.0 ports in the rear. The usb 2.0 ports are not working. The wireless adapter stopped working, but I plugged it into a 3.0 port and it worked fine. Tried a wired mouse and wireless keyboard in the 2.0 ports and nothing. In fact, the computer was not picking them up at all. All work fine in the 3.0 ports.
Any advice on this?
Thanks
Any advice on this?
Thanks
