My system is an ASUS cm5571 desktop PC
I am planning on completely revamping the computer. I currently have a Antec Neo ECO 520w continuous power PSU.
I need to know if it can safely run this system:
Motherboard: MSI 970A-G46 AM3+ http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
GPU: MSI Radeon HD 7750 2GB 800MHz core clock http://www.newegg.com/Product/Product.aspx?Item=N82E16814127709
Optical Drives: 1x CD-ROM (IDK exactly what it is)
HDD: Seagate Barracuda 1 TB 7200RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
RAM: 4x 4 GB sticks of G.Skill Ripjaws series 8GB(2x4GB) 240-pin DDR3 SDRAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
CPU: AMD FX-8350 Vishera 4.0GHz Socket AM3+ http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
Cpu fan: Cooler Master Hyper 212 120mm http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
I would really like some help before I drop 500 more bucks on this thing and not know to buy a PSU as well. Thank you in advance for any help
