What size power supply do I need?
  • Graphics Cards
  • Power Supplies
  • Graphics
January 9, 2013 2:25:31 PM
I have just built a new desktop with a zotac 650 ti graphics card. After being built the PC boots up but no signal is received to my tv/monitor. I have read previous threads that suggest the power supply is the problem. I was curious as to how big a power supply I needed. Right now I have a corsair cx750. All the fans run but they seem like they may be a little weak. I'm running a couple 200mm fans and a 140mm fan. I also have an AMD quad processor
Your help would be greatly appreciated.
More about : size power supply
a b U Graphics card
a b ) Power supply
January 9, 2013 2:28:08 PM
try using your gpu on another rig, 750w is more than enough
m
l
January 9, 2013 2:32:24 PM
cx430 will be enough
m
l
a c 182 U Graphics card
a b ) Power supply
January 9, 2013 2:36:37 PM
I answered you your previos thread.do not create extra thread
m
l
January 9, 2013 2:43:58 PM
Sorry this was my first time here. it was an accident
m
l
January 9, 2013 8:45:14 PM
Ok so i tried the gpu in another rig and everything worked perfectly fine. Is everyone sure that the power supply might not be at fault? i get no beep on start up
m
l
