Solved
Help is my GPU dead??
Hi ,
So I turn on my PC today and see that windows has some updates. SO I run them and restart my PC. WHen it starts up the resolution is really small. So I go to device mgr to Check the status of my video card and this is the error message it gave me!
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Its not the drivers... they are up to date!
Is my GPU dead? Or is it something else?
Thanks
9 answers Last reply Best Answer
More about help dead
  1. Reinstall the driver.
    I tried that and no luck. Nvidia installer cannot continue..This graphics driver could not find compatible graphics hardware. Also, I did clean out the old drivers first.
    Any suggestions?
    Thanks
  3. Please help!! Is my GPU Dead?
  4. Confirm that your monitor is connected to your graphics card rather than the motherboard.
  5. if this is a pre built you may need to use the vendor video drivers. also you may need to install the newest mb chipset drivers if one of the updates installed an older driver.
  6. Best answer
    Uninstall the old driver, reboot, run driversweeper, reboot, reinstall last know good version of your video driver, and don't ever install MS Update recommended video drivers.
  7. In addition to what J_E_D said, running Driver Sweeper in safe mode can also be helpful.
  8. You didn't tell us the video card model or what version of the drivers your trying to install nor where you downloaded them from.
Graphics Cards Graphics
