I've heard of devices such as noise filters, AC Line interference filters
and spike suppressors, but am not sure if any of these or other devices can
solve my problem.
I have a mobile DJ setup consisting of a mixer, CD player, amp, Furman Power
Conditioner and light controller in a case.
I also have a laptop, external hard drive, subwoofer, cordless mic and fog
machine.
The mixer, CD player, cordless microphone, external hard drive, light
controller and laptop are all plugged into the Furman. The ground for the
laptop is lifted with a 3 to 2 prong adaptor which eliminates a previous
ground loop isolation problem that used to exist (i.e humming).
The Furman and amp are plugged into the same extension cord with a 3-socket
adaptor and plugged into the wall. The subwoofer is plugged into the wall
with its separate extension cord. The fog machine is also plugged into the
wall with its own extension cord.
Supposedly, each wall socket that each extension cord was plugged into was
on a separate circuit. However, whenever I pressed the fog machine switch
and released it, I would hear a loud "POP" going through the speakers. As a
result, I could not use the fog machine with the risk that the sound would
blow the speakers.
If the fog machine was actually on the same circuit as the amp or subwoofer,
I assume that would explain the popping sound? If they were not on the same
circuit, but each wall socket had the same ground source, could that explain
this?
In either event, since I often cannot control how I plug in my equipment at
a location, is there any device that will actually decrease or eliminate the
popping sound (i.e. something that I can plug the fog machine into)?
><snip>
> blow the speakers.
> this?
><snip>
If you have used this equipment before without pops, then the location
wiring may be a problem. If you always have pops, then the fog machine
may be generating RF or line spikes to which the amplification equipment
is sensitive.
The first thing to try would be to check the power switch for the fog
machine. If it does not already have capacitors across the contacts,
install a cap for each switch contact. That will prevent "arcing" which
is a typical source for this type of noise problem.
I am not an electrician, so how do I do this? Opening up the fog machine,
and then what am I looking for?
The switch is actually a remote device that is plugged into the fog machine
with a 25 ft. long cord.
"Robert Gault" <robert.gault@worldnet.att.net> wrote in message
news:yU6lc.11035$Ut1.335428@bgtnsc05-news.ops.worldnet.att.net...
> Legaldeejay wrote:
> ><snip>
was
switch
As a
would
> > blow the speakers.
subwoofer,
same
explain
> > this?
> ><snip>
> is sensitive.
Legaldeejay wrote:
> Robert:
> Thanks for your response.
>>Legaldeejay wrote:
>>><snip>
> was
> switch
> As a
> would
>>>blow the speakers.
> subwoofer,
> same
> explain
>>>this?
>> ><snip>
>>is sensitive.
Ouch! Since I don't know how your fog machine is wired and even if I
did, you indicate having little experience in electronic or electrical
modifications, it would not be safe to proceed along this path.
That leaves open only power strips with built-in filtering. You will
have to hope they can isolate the noise which seems to originate in the
fog machine.
