Tom's Hardware > Forum > CPU & Components > Sound Cards > Audigy XP Reboot Problem
Forum CPU & Components : Sound Cards - Audigy XP Reboot Problem
When I play an MP3 or MPEG or anything that uses the sound card, at random times XP reboots! Anyone else have similar problems. My system temp seems fine, I have a 500 watt PS so power should be adequate. This has happened with each driver they have offered. Anyone else with this problem?
System Config:
Windows XP
500 Watt PS
P4 1.8
Asus P4T-E
512 MB RDRAM
ATI Radeon 8500
SB Audigy Platinum Int.
2 Maxtor 60GB 7200 ATA 100
Pioneer DVD
HP 9500i CDR/RW
Kingston NIC
Sponsored Links
Try different sound card drivers?
<font color=orange>Quarter</font color=orange> <font color=blue>Pounder</font color=blue> <font color=orange>Inside</font color=orange>
Reply to FatBurger
I have tried every XP driver they have posted.
Reply to Anonymous
Then I don't know what to suggest. Sorry.
Reply to FatBurger
- 0 +
Nice system.
<font color=red><i>Doctor Hooter</i></font color=red> <b>(·Y·)</b>
Reply to zpyrd
Check the system event log to see if it's rebooting because of a blue screen or not. If it is, post the stop error codes.
Reply to Novakain
- 0 +
Did you install the creative software or just the drivers? I usually only install the drivers and never have any problems.
Reply to Zlash
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 DustenH won the Uniformed badge
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
