Archived from groups: alt.video.ptv.replaytv (More info?)
I have tried recording Smallville from two different RTV units over the
last 3 weeks and each time it only records one minute and stops. There
are no programming conflicts and the machines have no problem recording
other shows. Any ideas?
On Thu, 20 May 2004 09:57:30 GMT, "BruceR" <brNOSPAM@hawaii.com>
The only ones I've ever had do that, were when there was no video from
the source. You get a "no video detected" error message. You could
check the source (s-video cables come loose more easily).
On one machine it recorded for a few minutes and the other did give me a
No Video message. However, both machines recorded other shows both
before and after. It's not a cable outage because it happens every week
just for Smallville. Maybe it has something to do with Kryptonite
mlloyd@5xxxmail.com5xxx
>> the last 3 weeks and each time it only records one minute and stops.
>> There are no programming conflicts and the machines have no problem
>> recording other shows. Any ideas?
> Mark Lloyd
> http://go.to/notstupid > http://notstupid.laughingsquid.com >
> "It is a curious thing that every creed promises a
> paradise which will be absolutely uninhabitable for
> anyone of civilized taste." -- Evelyn Waugh
On Thu, 20 May 2004 19:47:10 GMT, "BruceR" <brNOSPAM@hawaii.com>
Power outage? If power came back on, you may find the rest of the show
in a different recording.
>just for Smallville. Maybe it has something to do with Kryptonite >
I have no trouble with that show.
>From:Mark Lloyd
>> Mark Lloyd
>> http://go.to/notstupid >> http://notstupid.laughingsquid.com >>
Good thought but no power failure message from units and no indication
from my home automation system which logs power outages. It's a stumper!
>> me a No Video message. However, both machines recorded other shows
>> both before and after. It's not a cable outage
>> just for Smallville. Maybe it has something to do with Kryptonite >>
>> From:Mark Lloyd
>>>> stops. There are no programming conflicts and the machines have no
>>>> problem recording other shows. Any ideas?
>>> from the source. You get a "no video detected" error message. You
>>> could check the source (s-video cables come loose more easily).
>>> Mark Lloyd
>>> http://go.to/notstupid >>> http://notstupid.laughingsquid.com >>>
> Mark Lloyd
