Hello Everyone.
Before posting here, I searched for an answer both here and on Google. I got all sorts of answers like update or use older drivers etc. I read some answers that dont pertain to me and then an answer or two Im unsure how to do what they suggested. So let me start off with my system specs:
Brand new build
Thermaltake Chaser MK-1
Intel i5-3750K
Asus P8Z77-V LK
Corsair H100i Cooler
16GB Corsair Vegeagence 1600 DDR3 RAM (4 sticks)
GIGABYTE GV-N670OC-2GD GeForce GTX 670 Windforce OC 2048MB GDDR5 256-bit PCI
Samsung 840 Pro-Series 128GB SSD
Corsair HX750 PSU
Windows Home Premium OEM
Initially I did a out of case set-up before installing. CPU, Mobo, graphic card. Started it and I was able to see the messaging on the screen. So I disconnected and installed everything. Powered up and installed windows! Hurray!!!
I initially only installed the LAN drivers from my mobo disk so I can then install all the latest drivers for everything from online as most and NewEgg's videos suggest. That worked well. Installed the latest driver from Gigabyte for the graphic card... and the screen resolution reset automatically and now looked correct, Prior everything was at a default setting big and clunky. So I was happy once i saw it reset.
While navigating in explorer to the Corsair site I notice the mouse was sluggish. It would freeze for a second or two. This would happen a couple of times and then I get a screen blackout for 2-3 seconds. After the screen comes back on I got the following error message at the bottom of my screen:
Display driver stopped responding and has recovered.
Display driver NVIDIA Windows Kernel Mode Driver Version 310.90 has stopped working and has successfully recovered.
I figured maybe it was because I just installed the driver. So I continued on with getting to the corsair site. I got to the site and it started again, mouse acting up and this time the screen went black and did not return. I had to reset the computer. I watched part 3 of Neweggs How to Build A PC again... especially the installing windows and drivers etc and re-did every step. Reformatting my SSD, re-installing Windows and the drivers. And I still get the issue.
I read here and on other forums that it could be an old/new driver issue so I tried just using the driver that came with the card... same issue.
I even tried it with both new and old drivers after installing all the Windows updates and still have the issue.
So I tried a lot of the ways I read resolutions for... I checked the Geforce forums as well... Restore to old driver... update to new driver... remove and re-install driver... turn off system for 1/2 hour etc. And still I have the issue.
In the divice manager, everything seems to be ok. I checked the graphic card and it says working normally. I dont know of another way to check it. So Im really at a loss here.
I was debating buying a pre-made system as I normally would but heard so many horror stories with the Gaming system providers online... I decided to build my own. and Im 99% there. I just cant figure out this issue.
I cant do anything without it freezing up and blacking out.
Can anyone shed some light on this issue?
I did not OC anything... dont know how to be honest. Everything is from factory new packaging. My temps are not hot... I see in corsair link that my CPU is about 22c Mobo & Disks are 20 - 23c and my graphic card is only 26c idle. So the system seems to be running pretty cool.
I did a ram test with Memtest86+ ran it over night for 8+ hours and It passed with 0 errors.
I installed OCCT and tried to test the system with that. As the system heats up i see my fans speed up on the system and on the GPU. At full stress for 10 minutes my CPU is 42c and the GPU at 56c
When doing the GPU test I see the furry thing moving under normal testing, but when I select error check... it does not move meanwhile all the readings still are active including frame rate.
Finally I read here on Toms that it could be that the board may be overclocked or unstable from the factory... and that someone else who has this problem should try to slow it down. I dont know even where to begin on how to slow down the clock speed let alone know where i can find that information.
Being my first computer and spending almost $1600 in parts gas and tolls etc. Its so frustrating that its not working.
Can anyone help me with this issue?
Thank you!!
Brand new build
Intel i5-3750K
Asus P8Z77-V LK
Corsair HX750 PSU
Thank you!!
