Sign-in / Sign-up
Gigabyte gtx 660 ti 3gb problem
  • Graphics Cards
  • Power
  • Gigabyte
  • Graphics
Last response: in Graphics Cards
January 11, 2013 3:51:47 AM
so I got my pc together and now I got to the part of plugging the PCIe power connectors to the 6 pin connector on the top of the graphics card, well there is two power connectors, one being a 6 pin, and the other being a 6+2 pin, which one do I plug it into? just the 1 6 pin or just the 1 8 pin or both?
More about : gigabyte gtx 660 3gb problem
a b U Graphics card
January 11, 2013 4:04:29 AM
you can plug the 1x 6 pin in or the 6 pin of the 6+2 pin in. Both will work.
m
l
January 11, 2013 4:35:56 AM
so only use 1 connection and on the other?
m
l
January 11, 2013 4:42:51 AM
this is the 2 connectors I'm talking about, http://i48.tinypic.com/289rf9.png
there is 1 there has 8 pins and the other has 6 pins, do I plug it into both of those power connectors or just one of them?
m
l
a c 332 U Graphics card
January 11, 2013 4:56:12 AM
Both.
m
l
January 11, 2013 4:58:07 AM
Mousemonkey said:
Both.
now that you said that, I have another question, what would happen if the computer was powered down but not unplugged and the power supply switch was set to off but plugged in and I unplugged the pcie power connector from the gpu?
m
l
a c 182 U Graphics card
January 11, 2013 4:59:17 AM
Your gpu will not run.do not do that.
m
l
January 11, 2013 5:00:01 AM
would it ruin the gpu?
m
l
January 11, 2013 5:19:27 AM
I've done that many times when changing and swapping cards about and never had any problems. Just make sure everything is plugged back in correctly before powering up again.
m
l
January 11, 2013 5:24:10 AM
I did all as told and the gpu wont power on, what do I do?
m
l
January 11, 2013 5:29:00 AM
Assuming that your PSU is up to the job, you could have a faulty card.
m
l
January 12, 2013 1:46:01 PM
you must connect all pins (6 and 6+2) as the card needs all that power. you wrote it as if it was optional to connect just 6 or 6+2 pins.
best
revro
m
l
