So I just transferred the CPU: 3770 3.4ghz /RAM: 8gb ddr3/Motherboard(stock Dell motherboard) from my old Dell 8500 into a CM Storm Stryker case with a New PSU and a GTX 680.
I had a few problems finding out where to connect the wires for the front panel, so the usb 3's dont work, and the HD Activity LED doesn't work.
I can deal with this till I get a new motherboard. But the main thing thats wrong is when I try and power on my computer, the lights go on and the fans start spinning for about 7 seconds and nothing comes up on screen, then the whole computer just shuts off. Then about 3 seconds later it turns on again without me pressing anything and starts booting, but before it will load windows it says: Fan error etc. press F1 to continue etc. then I press F1 and everything works like normal including the fans.
Just wondering if this could be fixed, I think it has to do with my motherboard.
