Audio Card with DSP vs onboard audio
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.games (More info?)
I do not know how to determine the CPU load of audio on a motherboard or how
to determine if the sound includes a digital signal processor (DSP). I
assume a DSP, especially for older CPUs (600 MHz. or so) is a big improvement
because it offloads a lot of processing from the CPU. I am interested only
in stereo. How can I know if an add-in sound card with a DSP is actually an
improvement? Does the DSP overweigh other issues, eg. does a cheap Mad Dog
Prowler 4.1 DSP sound card offer an improvement over the motherboard sound of
a Compaq DeskPro ENS/P600? Truth is, I've been looking for but have not seen
a treatise on this topic. Does anyone have any links for me to pursue?
Thanks in advance for your help.
More about : audio card dsp onboard audio
Hi Eric,
In general, a dedicated sound card is the best option.
How many speakers/watts do you have in your configuration?
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Visit my MSN Zone.com and Gaming Help Site: http://mvps.org/nibblesnbits
MS Games Help and Support Center: http://support.microsoft.com/?pr=gms
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"Eric Lewis" <EricLewis@discussions.microsoft.com> wrote in message news:67759175-6330-4A0E-B8FB-41F34E9F84E6@microsoft.com...
Hi Eric,
Hi Jimmy S. I am struggling to rate your post helpful but no option to do
that appears (omit standard complaints about programmers) but I did say your
post did not answer the question though it was quite helpful and the links
you gave me include much about ICS I have been looking for. I saved the link
in my Favorites. Thank you for them.
I plan to put the analog stereo output into a Bose receiver/amplifier and DO
NOT plan to use the multiple channel output capability of this cheapo card
(free after rebates). So I don't think the number of speakers or watts is
really relevant here. I agree that in general an addin sound card is an easy
choice but the Compaq computer I plan to use has an extremely low profile
allowing only two PCI cards but also making this computer a good choice for a
rack of audio/visual equipment. I like the idea of a very low profile a lot
more than the small cube formfactor now being offered for Home Entertainment
Center computers. So I don't want to give up an empty slot willy nilly.
If I understand this correctly, a DSP does offload the CPU and being
digital, is not one DSP the same as another in terms of quality while within
the processing power of the DSP? This card claims 4.1 capability and
suggests this is a big improvement but does not speak to any possible
improvement when used in a stereo mode that presumably reduces the computing
load by a factor of the channels or 60%. I've scoured the Compaq/HP web site
and all available documentation but none of it speaks to whether there is a
DSP onboard. I've visually scoured the mb itself but my knowledge of actual
DSP chips is not sufficient for me to be sure of what I am looking at. A
slower DSP onboard that handles stereo ok would, I believe, generate similar
stereo audio as a faster add-in DSP would when it is running at only two
fifths of its processing capacity.
Perhaps I am wrong in this analysis and if you can set me straight that
would help. Thanks again for your post.
"Jimmy S." wrote:
> Hi Eric,
"Jimmy S." wrote:
> Hi Eric,
Hi Eric,
I tried to locate information to determine which Compaq branded
home computer systems ship with DSP onboard, and like yourself
I was unable to find the data that we needed. I think the absolute
best next step towards a going forward solution would be to send
in inquiry to the Customer Care folks at HP/Compaq via this URL:
http://h10025.www1.hp.com/ewfrf/wc/siteHomeC?lc=en&cc=u...
"Eric Lewis" <EricLewis@discussions.microsoft.com> wrote in message news:437E7372-E4EE-42C6-BA59-C26D874AD8A8@microsoft.com...
| "Jimmy S." wrote:
| > Hi Eric,
Hi Eric,
| "Jimmy S." wrote:
| > Hi Eric,
Hi Jimmy S: (still wondering about the rating system) I followed your link to
the HP/Compaq site and found the document
http://forums2.itrc.hp.com/service/forums/bizsupport/qu...
that gives cpu util. for a 733 MHz PIII with/without sound that clearly shows
there is no DSP onboard.
"I discovered that when both channels of the stereo output are active, CPU
utilization goes to 80-100%. When it "hits the wall" at 100%, audio
(understandably) breaks up and becomes distorted, and the application itself
become erratic.
As a sanity check, I disabled the onboard sound via BIOS and measured CPU
utilization again with our application running... now less than 15%,
including overhead from Windows Task Manager. Everything is happy and stable."
So a PCI slot will go to a sound card because I am assuming the models are
not so different (T5700 vs ENS/P600). Thanks very much for your help. Eric
Lewis
"Jimmy S." wrote:
> Hi Eric,
> | "Jimmy S." wrote:
> | > Hi Eric,
become erratic.
Lewis
"Jimmy S." wrote:
> Hi Eric,
> | "Jimmy S." wrote:
> | > Hi Eric,
Hi Eric,
I'm glad I was able to offer you a little guidance on your path
to discovery, and I'm delighted that you found your answer. :-)
Please don't worry about the rating system. Most of us who
answer use Outlook Express to read the newsgroups and we
don't see any of that ratings stuff. Thanks just the same though!
"Eric Lewis" <EricLewis@discussions.microsoft.com> wrote in message news:32591375-8BB8-48F2-B829-466124747E75@microsoft.com...
| become erratic.
| Lewis
| "Jimmy S." wrote:
| > Hi Eric,
| > | "Jimmy S." wrote:
| > | > Hi Eric,
Hi Eric,
| become erratic.
| Lewis
| "Jimmy S." wrote:
| > Hi Eric,
| > | "Jimmy S." wrote:
| > | > Hi Eric,
Related ressources:
- ForumOn-board audio vs dedicated sound card , worth it?
- ForumSB Audigy 2 Value vs . Onboard HD Audio (MSI P55-CD53)
- ForumPCIe for Audio & DSP Cards
- ForumOnboard analog cables vs sound card optical ??
- ForumOn-Board Sound vs . PCI Sound Card
- ForumOnboard motherboard audio vs sound card
- ForumSound card vs onboard audio - which is better
- ForumFS: Creamware Pulsar DSP card
- ForumOnboard audio vs . sound card ?
- ForumSound card vs onboard 'blu ray audio '
- Forum2.1 speakers vs digital audio output on onboard realtek card
- ForumHELP!!! Please with Windows XP
- ForumHelp with RollerCoaster Tycoon 3 install
- ForumProblem with installing Aliens Versus Predator Gold Edition
- Forumi need help with battlefield 2 demo running
- ForumOlder Sidewinder Force Feedback PRO joystick with WinXP???..
- ForumTWS2 gameport issues (how to turn "poll with interrupts of..
- ForumTrouble with Call of Duty game
- ForumAGP vid card necessary?
- ForumCD-ROM problem with EA and microsoft games
- More resources
Read discussions in other Windows XP categories
