Compatibility on parts and what motherboard to pick.
2 answers Last reply
More about compatibility parts motherboard pick
  1. Everything seems good except for the psu. Any psu not 80+ certified is almost like a bomb, but you don't know when it's going to blow. Okay ? Good.
    The mobo choice depends on what conectors you want on the motherboard and which kind of upgrades you want to be able to do in the future.
    This is the cheapest Atx board : http://www.newegg.com/Product/Product.aspx?Item=N82E16813157291
    It should be okay for your "cheap computer" project :P.
    - The Brownie
  2. The motherboard you linked is not compatible with the Processor. Phenom II X4 965 requires an AM3 (or AM3+) socket. I would suggest you get a socket AM3+ motherboard so that you can upgrade to an FX series processor if you need to. Also, there is no optical drive, however, you could do without that if you don't plan on installing the OS and any programs from a CD/DVD. I would suggest including one unless you can scavenge that from a previous computer.
    Here's a build that would work for you.
    CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($94.98 @ Outlet PC)
    Motherboard: Asus M5A97 LE R2.0 ATX AM3+ Motherboard ($74.99 @ Newegg)
    Memory: Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1333 Memory ($39.98 @ Outlet PC)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.86 @ Compuvest)
    Video Card: MSI Radeon HD 7750 2GB Video Card ($88.48 @ SuperBiiz)
    Case: Thermaltake VL80001W2Z ATX Mid Tower Case ($34.99 @ Newegg)
    Power Supply: Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply ($24.99 @ Newegg)
    Optical Drive: Samsung SH-224BB DVD/CD Writer ($16.98 @ Outlet PC)
    Total: $435.25
    (Generated by PCPartPicker 2013-03-01 22:40 EST-0500)
New Build AMD Motherboards Compatibility Systems Product
