Solved
Need help deciding on monitor for this build
Hello community,
So I need some help with my new gaming build (shown below). I'm struggling on choosing my monitor and making sure I have enough GPU power to make the monitor worth it. I like the idea of a 144Hz monitor and the awesome fluid FPS that can come with it. I'm just wondering if it is worth it with this build. Currently I only have a GTX 670 and don't really want to go SLI right now so I can keep the budget a little lower. I will be upgrading the GPU in a year-ish when the new NVIDIA architecture launches. So I guess the big question is is this worth it with my build?
Oh and feel free to critique the build etc. I would love some helpful comments. And the reason I'm going with an 3770k is because I can buy it for the same price as a 3570k so I figured why not :D
PCPartPicker part list: http://pcpartpicker.com/p/GSXO
Price breakdown by merchant: http://pcpartpicker.com/p/GSXO/by_merchant/
Benchmarks: http://pcpartpicker.com/p/GSXO/benchmarks/
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($229.99 @ Microcenter)
CPU Cooler: Noctua NH-U9B SE2 37.9 CFM CPU Cooler ($60.99 @ Newegg)
Motherboard: Gigabyte G1.Sniper 3 EATX LGA1155 Motherboard ($269.99 @ Amazon)
Memory: G.Skill Ripjaws Series 16GB (4 x 4GB) DDR3-1600 Memory ($104.99 @ Newegg)
Video Card: EVGA GeForce GTX 670 2GB Video Card ($380.04 @ Newegg)
Power Supply: NZXT HALE 90 750W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($132.72 @ Amazon)
Optical Drive: Asus BW-14D1XT Blu-Ray/DVD/CD Writer ($99.99 @ Amazon)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($297.54 @ Adorama)
Other: NZXT Phantom 630 (Grey) ($179.99)
Total: $1756.24
(Generated by PCPartPicker 2013-03-01 20:37 EST-0500)
8 answers Last reply Best Answer
More about need deciding monitor build
  1. Grab 3 60htz monitors and do some surround... plus 2 660's will perform better anyways...
    but if your dead set on a single monitor system with 144htz, go for what you got... but I know I wouldn't, once you go triple monitor you don't go back.
    Right now, this is a REALLY awesome deal:
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2898965&Sku=A204-2460
  2. Best answer
    -no reason to get a sniper 3 board
    -no reason for 16gb of ram for gaming.
    -get a 7970 instead. performs better for the money. sucks a little more power though
    -id get a IPS panel instead of a fast 120/144hz TN. its slower and all but colours are much more vibrant, viewing angles dont suck, and it just looks better. i personally dont see any lag from my IPS display from asus. highly recommend you get these instead
    -surround isnt for everyone. i suck so badly with them. i think i had a 20 deathstreak in COD using 3 monitors
    -optical media is dying. no reason to blow that much money on a blu ray drive
    get this
    http://pcpartpicker.com/p/GTia
    monitor
    http://us.ncix.com/products/?sku=75619&promoid=1345
    ram
    http://us.ncix.com/products/?sku=74758&promoid=1321
    case. really dont see the point of spending so much on a case. the 100 dollar mark is where cases tend to peak for its value and function. after that it just goes downhill until you get something like a silverstone tj11
    http://us.ncix.com/products/?sku=75051
  3. Thanks for the response!
    I've thought about triple monitors, but I know I'd have to get two GPUs. And two 660s will perform better than one 670 overclocked? Is that going to be cheaper than a single 670? If not I may as well go dual 670s right?
    id suggest trying surround for at least 3hrs before moving in on the purchase. 2 660s will perform better than a 680, but then it instantly blocks upgrade paths and the 2gb frame buffer isnt enough for most. if you want surround, amd is the way to go.
    get this
    monitor
    ram
    Interesting build. I actually already have an SSD. So why did you choose that Gigabyte motherboard? Also according to PC Part Picker the 7970 is still more expensive than the 670. And I haven't seen that IPS monitor before. That is an awesome price for something like that!
  6. honestly dude, surround is awesome. I will agree, it does take a learning curve... but it is the most impressive thing ever. Do it, you wont be upset you did.
    the gigabyte board i chose has all the necessary features that you will ever need. you dont need a plx board like the sniper 3 for 2way SLI
    its a bit more expensive but it could be worth it as it does perform better and comes with crysis 3
  8. Best answer selected by rdubs628.
Build Monitors Systems
