ag50 said:
Thanks for the advice, however I'm not sure if i'm looking in the wrong places but the Xeon CPU that you suggested seems to be more expensive than the 3570k everywhere, and for what I need it for I'm not sure theres a whole lot difference in it. My laptop has a lesser i5 in and is more than sufficient for what I use it for.
How bad is the PSU I selected, I don't really want to spend more than I have to on the PSU and reviews on Amazon for it are very good. Same goes with the case really, don't want to spent more than I have to.
Thanks for GPU advice that looks to be a good choice.
How would this build compare to my laptop, it does everything I want with no problem from a photoshop and video editing side of things, its specs are:
CPU: Core i5-2410M
RAM: 6GB
GPU: AMD Radeon HD 6370M with 1GB Dedicated DDR RAM.
How does my Radeon HD 6370M in the laptop compare to the Intel HD 4000 Graphics?
http://www.tomshardware.com/reviews/gaming-graphics-car...
Here's a good place to start for graphics cards. But the 660 is way overpowered for just minor photoshop fun. If anything, you should just grab a 7750 or 7770 which will allow plenty of power for that. The 7750 i would specifically recommend as it doesn't need separate power connections... it draws enough power from the motherboard PCI slot.
As for the CPU, don't get a Xeon. They are made for server computers, you would do alot better with a consumer grade CPU. If you plan on overclocking eventually, grab a 3570k, but if not, you should be able to settle for a 3570, which performs the same, but doesn't have the overclock capability.
Finally, I generally stay away from OCZ because their quality is sub-par. Look on Newegg and search for PSU's with the best rating. Any Seasonic, Corsair, Antec, NZXT or something like that will do fine.
Also, you don't need a new case if you don't want to. Unless you are running it out of a cardboard box, any case should be fine.
